hi all
LCD: rocktech RK043FN66HS
MCU :MIMXRT1064
PWM pin: IOMUXC_GPIO_B1_15_FLEXPWM4_PWMA03
I have taken example code of pwm. In this example code simple led is works perfectly but same way lcd backlight brightness is not works.
I have setup and configure lcd backlight pin as pwm (IOMUXC_GPIO_B1_15_FLEXPWM4_PWMA03), in pwm source code i have change PMW1 to PWM4 and submodule 3.
Any correction in above steps? please let me know.
Hi @nikesh ,
Which demo are you referring to ? Please kindly clarify.
Kan
Hi @nikesh ,
Thanks for the information! Is it possible to have your code for a review? I will try to reproduce it here.
Kan
