Is it possible to write something in flash while running debug mode in flash
216 次查看
abs_setian
Hello.
I want to write my configuration data into flash memory while running debug mode
Config data area starts from 0x61000000(its not an program memory area)
Is this possible to read and write config data while debug mode?
178 次查看
Omar_Anguiano
If your device is XIP then it may be difficult to write while reading so it would be convenient to execute the part that writes to the flash to RAM so we avoid that collision on the bus.
Omar
