Is digital inputs are 5V tolerant? I looked at the reference manual and datasheet but could not find any info about it.
#iMXRT1021
Solved! Go to Solution.
Hi @ergingursoy
I hope that you are doing great!
No, digital pins or GPIO pins are not 5V tolerant.
RT1021 GPIOS can work with 1.8v or 3.3v nominal voltage.
For example , If we still want to know the maximum input voltage GPIOs can tolerate, we can take a look at the below specification.
The maximum input voltage of input pins is limited to maximum of the NVCC_GPIO rail.
All the best,
Diego
Hi @ergingursoy
All the best,
Diego
