IMXRT1061 sanity check failed Zephyr
MCW
Hi all,
I use IMXRT1061 with Zephyr OS.
The error log shows [00:00:07.157,000] <err> mpu: Partition 2: sanity check failed.
I guess it is related to the setting of device tree.
	cpus {
		#address-cells = < 0x1 >;
		#size-cells = < 0x0 >;
		cpu@0 {
			device_type = "cpu";
			compatible = "arm,cortex-m7";
			reg = < 0x0 >;
			#size-cells = < 0x1 >;
			mpu: mpu@e000ed90 {
				compatible = "arm,armv7m-mpu";
				reg = < 0xe000ed90 0x40 >;
				arm,num-mpu-regions = < 0x10 >;
How could I deal with this problem?
Doris
Omar_Anguiano
Hello
I hope you are well.
For better support on Zephyr please you can upload your questions to one of the help channels for Zephyr: Getting Started Guide — Zephyr Project Documentation
Omar
Omar_Anguiano
Hello
Omar
