IMXRT1060 Converting Monochrome to RGB565 using PXP
michaelsmorto
We are working with 2 cameras, HM01B0 and the HM0360, which only support Bayer or Monochrome formats.  So we have been using a monochrome pallet to convert to RGB565 format.  We have been trying to use PXP to do the conversion with varying degrees of success.
For instance, since the data is 8-bit monochrome we started with using Y8 for the input buffer and RGB565 as the output buffer.  While the image looks right its all RED:
If we use one of YUV 422 1p fomats as input:
We get 2 half images.  The camera is set to use QVGA format.
Any suggestions would be helpful - or are we wasting our time.
PS> Using a Teensy 4.1 with PXP ported to work in an Arduino IDE.  Teensy 4.1 is a IMXRT1062 based MCU.  The sketch we use is as follows (the commands should be familar):
#include "Camera.h"
#include "T4_PXP.h"
//Specify the pins used for Non-SPI functions of display
//#define TFT_DC 4
//#define TFT_CS 5
//#define TFT_RST 2
#define TFT_DC 9
#define TFT_CS 7
#define TFT_RST 8
#define use9488
#if defined(use9488)
#include <ILI9488_t3.h>
ILI9488_t3 tft = ILI9488_t3(TFT_CS, TFT_DC, TFT_RST);
#define TFT_BLACK ILI9488_BLACK
#define TFT_YELLOW ILI9488_YELLOW
#define TFT_RED ILI9488_RED
#define TFT_GREEN ILI9488_GREEN
#define TFT_BLUE ILI9488_BLUE
#define CENTER ILI9488_t3::CENTER
#else
#include <ILI9341_t3n.h>
ILI9341_t3n tft = ILI9341_t3n(TFT_CS, TFT_DC, TFT_RST);
#define TFT_BLACK ILI9341_BLACK
#define TFT_YELLOW ILI9341_YELLOW
#define TFT_RED ILI9341_RED
#define TFT_GREEN ILI9341_GREEN
#define TFT_BLUE ILI9341_BLUE
#define CENTER ILI9341_t3n::CENTER
#endif
#include "TMM_HM0360/HM0360.h"
HM0360 himax;
Camera camera(himax);
#define CameraID 0x0360
#define SCREEN_ROTATION 0
#define MIRROR_FLIP_CAMERA
framesize_t camera_framesize = FRAMESIZE_QVGA;
bool useGPIO = false;
uint8_t bytesperpixel_in = 1;
uint8_t bytesperpixel_out = 2;
uint16_t FRAME_HEIGHT, FRAME_WIDTH;
bool pxpStarted = 0;
uint16_t outputWidth, outputHeight;
// Define Palette for Himax Cameras
#define MCP(m) (uint16_t)(((m & 0xF8) << 8) | ((m & 0xFC) << 3) | (m >> 3))
static const uint16_t mono_palette[256] PROGMEM = {
    MCP(0x00), MCP(0x01), MCP(0x02), MCP(0x03), MCP(0x04), MCP(0x05), MCP(0x06),
    MCP(0x07), MCP(0x08), MCP(0x09), MCP(0x0a), MCP(0x0b), MCP(0x0c), MCP(0x0d),
    MCP(0x0e), MCP(0x0f), MCP(0x10), MCP(0x11), MCP(0x12), MCP(0x13), MCP(0x14),
    MCP(0x15), MCP(0x16), MCP(0x17), MCP(0x18), MCP(0x19), MCP(0x1a), MCP(0x1b),
    MCP(0x1c), MCP(0x1d), MCP(0x1e), MCP(0x1f), MCP(0x20), MCP(0x21), MCP(0x22),
    MCP(0x23), MCP(0x24), MCP(0x25), MCP(0x26), MCP(0x27), MCP(0x28), MCP(0x29),
    MCP(0x2a), MCP(0x2b), MCP(0x2c), MCP(0x2d), MCP(0x2e), MCP(0x2f), MCP(0x30),
    MCP(0x31), MCP(0x32), MCP(0x33), MCP(0x34), MCP(0x35), MCP(0x36), MCP(0x37),
    MCP(0x38), MCP(0x39), MCP(0x3a), MCP(0x3b), MCP(0x3c), MCP(0x3d), MCP(0x3e),
    MCP(0x3f), MCP(0x40), MCP(0x41), MCP(0x42), MCP(0x43), MCP(0x44), MCP(0x45),
    MCP(0x46), MCP(0x47), MCP(0x48), MCP(0x49), MCP(0x4a), MCP(0x4b), MCP(0x4c),
    MCP(0x4d), MCP(0x4e), MCP(0x4f), MCP(0x50), MCP(0x51), MCP(0x52), MCP(0x53),
    MCP(0x54), MCP(0x55), MCP(0x56), MCP(0x57), MCP(0x58), MCP(0x59), MCP(0x5a),
    MCP(0x5b), MCP(0x5c), MCP(0x5d), MCP(0x5e), MCP(0x5f), MCP(0x60), MCP(0x61),
    MCP(0x62), MCP(0x63), MCP(0x64), MCP(0x65), MCP(0x66), MCP(0x67), MCP(0x68),
    MCP(0x69), MCP(0x6a), MCP(0x6b), MCP(0x6c), MCP(0x6d), MCP(0x6e), MCP(0x6f),
    MCP(0x70), MCP(0x71), MCP(0x72), MCP(0x73), MCP(0x74), MCP(0x75), MCP(0x76),
    MCP(0x77), MCP(0x78), MCP(0x79), MCP(0x7a), MCP(0x7b), MCP(0x7c), MCP(0x7d),
    MCP(0x7e), MCP(0x7f), MCP(0x80), MCP(0x81), MCP(0x82), MCP(0x83), MCP(0x84),
    MCP(0x85), MCP(0x86), MCP(0x87), MCP(0x88), MCP(0x89), MCP(0x8a), MCP(0x8b),
    MCP(0x8c), MCP(0x8d), MCP(0x8e), MCP(0x8f), MCP(0x90), MCP(0x91), MCP(0x92),
    MCP(0x93), MCP(0x94), MCP(0x95), MCP(0x96), MCP(0x97), MCP(0x98), MCP(0x99),
    MCP(0x9a), MCP(0x9b), MCP(0x9c), MCP(0x9d), MCP(0x9e), MCP(0x9f), MCP(0xa0),
    MCP(0xa1), MCP(0xa2), MCP(0xa3), MCP(0xa4), MCP(0xa5), MCP(0xa6), MCP(0xa7),
    MCP(0xa8), MCP(0xa9), MCP(0xaa), MCP(0xab), MCP(0xac), MCP(0xad), MCP(0xae),
    MCP(0xaf), MCP(0xb0), MCP(0xb1), MCP(0xb2), MCP(0xb3), MCP(0xb4), MCP(0xb5),
    MCP(0xb6), MCP(0xb7), MCP(0xb8), MCP(0xb9), MCP(0xba), MCP(0xbb), MCP(0xbc),
    MCP(0xbd), MCP(0xbe), MCP(0xbf), MCP(0xc0), MCP(0xc1), MCP(0xc2), MCP(0xc3),
    MCP(0xc4), MCP(0xc5), MCP(0xc6), MCP(0xc7), MCP(0xc8), MCP(0xc9), MCP(0xca),
    MCP(0xcb), MCP(0xcc), MCP(0xcd), MCP(0xce), MCP(0xcf), MCP(0xd0), MCP(0xd1),
    MCP(0xd2), MCP(0xd3), MCP(0xd4), MCP(0xd5), MCP(0xd6), MCP(0xd7), MCP(0xd8),
    MCP(0xd9), MCP(0xda), MCP(0xdb), MCP(0xdc), MCP(0xdd), MCP(0xde), MCP(0xdf),
    MCP(0xe0), MCP(0xe1), MCP(0xe2), MCP(0xe3), MCP(0xe4), MCP(0xe5), MCP(0xe6),
    MCP(0xe7), MCP(0xe8), MCP(0xe9), MCP(0xea), MCP(0xeb), MCP(0xec), MCP(0xed),
    MCP(0xee), MCP(0xef), MCP(0xf0), MCP(0xf1), MCP(0xf2), MCP(0xf3), MCP(0xf4),
    MCP(0xf5), MCP(0xf6), MCP(0xf7), MCP(0xf8), MCP(0xf9), MCP(0xfa), MCP(0xfb),
    MCP(0xfc), MCP(0xfd), MCP(0xfe), MCP(0xff)};
uint8_t DMAMEM s_fb[(480) * 320] __attribute__((aligned(64)));
uint16_t d_fb[(480) * 320] __attribute__ ((aligned (64)));
const uint32_t sizeof_s_fb = sizeof(s_fb);
const uint32_t sizeof_d_fb = sizeof(d_fb);
uint16_t  image_width = 0;
uint16_t  image_height = 0;
void setup() {
  Serial.begin(9600);
  while (!Serial && millis() < 5000) {}
  if (CrashReport) {
    Serial.print(CrashReport);
    Serial.println("Press any key to continue");
    while (Serial.read() != -1) {}
    while (Serial.read() == -1) {}
  // Start ILI9341
  tft.begin();
  tft.setRotation(3);  // testing external rotation
  test_display();
  start_camera();
  uint32_t imagesize;
  imagesize = FRAME_WIDTH * FRAME_HEIGHT;
  //Note for rotation 0 width and height reversed
  image_width = FRAME_WIDTH;
  image_height = FRAME_HEIGHT;
  showCommands();
  start_pxp();
void loop() {
  int ch;
  if (Serial.available()) {
    uint8_t command = Serial.read();
    switch (command) {
      case '0':
        Serial.println(" PXP rotation 0....");
        PXP_ps_output(0, false, 0.0f);
        break;
      case '1':
        Serial.println(" PXP rotation 1....");
        PXP_ps_output(1, false, 0.0f);
        break;
      case '2':
        Serial.println(" PXP rotation 2....");
        PXP_ps_output(2, false, 0.0f);
        break;
      case '3':
        Serial.println(" PXP rotation 3....");
        PXP_ps_output(3, false, 0.8f);
        break;
      case 'd':
        camera.debug(!camera.debug());
        if (camera.debug()) Serial.println("Camera Debug turned on");
        else Serial.println("Camera debug turned off");
        break;
      case 'f':
        capture_frame(true);
        //tft.writeRect8BPP(0, 0, FRAME_WIDTH, FRAME_HEIGHT, s_fb,
        //                      mono_palette);
        tft.setRotation(0);
        break;
      case 's':
        Serial.println("Starting PXP.....");
        start_pxp();
        break;
      case 't':
        test_display();
        break;
      case '?':
        showCommands();
      default:
        break;
void start_pxp(){
  PXP_init();
  memset(s_fb, 0, sizeof_s_fb);
  memset(d_fb, 0, sizeof_d_fb);
  pxpStarted = true;
void draw_frame(uint16_t width, uint16_t height, const uint16_t *buffer) {
  tft.writeRect(CENTER, CENTER, width, height, buffer );
void capture_frame(bool show_debug_info){
  memset((uint8_t *)s_fb, 0, sizeof(s_fb));
  camera.setMode(HIMAX_MODE_STREAMING_NFRAMES, 1);
  camera.useDMA(false);
  camera.readFrame(s_fb , sizeof_s_fb);
  arm_dcache_flush((uint8_t*)s_fb, sizeof_s_fb); // always flush cache after writing to DMAMEM variable that will be accessed by DMA
  Serial.println("Finished reading frame");
void start_camera(){
  // Setup for OV5640 Camera
  // CSI support
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  uint8_t reset_pin = 14;
  uint8_t powdwn_pin = 15;
  pinMode(powdwn_pin, INPUT);
  pinMode(reset_pin, INPUT_PULLUP);
  uint8_t status = 0;
  //camera.setPins(29, 10, 33, 32, 31, 40, 41, 42, 43);
  status = camera.begin(camera_framesize, 15, useGPIO);
  camera.setPixformat(YUV422);
  Serial.printf("Begin status: %d\n", status);
  if (!status) {
    Serial.println("Camera failed to start - try reset!!!");
    //Serial.printf("\tPin 30:%u 31:%u\n", digitalReadFast(30), digitalReadFast(31));
    Serial.printf("\tPin rst(%u%u PowDn(%u%u\n", reset_pin, digitalRead(reset_pin), powdwn_pin, digitalRead(powdwn_pin));
    pinMode(reset_pin, OUTPUT);
    digitalWriteFast(reset_pin, LOW);
    delay(500);
    delay(500);
    if (!status) {
      Serial.println("Camera failed to start again program halted");
      while (1) {}
  Serial.println("Camera settings:");
  Serial.print("\twidth = ");
  Serial.println(camera.width());
  Serial.print("\theight = ");
  Serial.println(camera.height());
  //Serial.print("\tbits per pixel = NA");
  //Serial.println(camera.bitsPerPixel());
  Serial.println();
  Serial.printf("TFT Width = %u Height = %u\n\n", tft.width(), tft.height());
  FRAME_HEIGHT = camera.height();
  FRAME_WIDTH = camera.width();
  Serial.printf("ImageSize (w,h): %d, %d\n", FRAME_WIDTH, FRAME_HEIGHT);
  // Lets setup camera interrupt priorities:
  // camera.setVSyncISRPriority(102); // higher priority than default
  camera.setDMACompleteISRPriority(192); // lower than default
  camera.setMode(HIMAX_MODE_STREAMING, 0); // turn on, continuous streaming mode
void test_display() {
  tft.setRotation(3);
  tft.fillScreen(TFT_RED);
  delay(500);
  tft.fillScreen(TFT_GREEN);
  delay(500);
  tft.fillScreen(TFT_BLUE);
  delay(500);
  tft.fillScreen(TFT_BLACK);
  delay(500);
  tft.setRotation(0);
void showCommands(){
  Serial.println("\n============  Command List ============");
  Serial.println("\ts => Start PXP");
  Serial.println("\tf => Capture normal frame");
  Serial.println("\tt => Test display");
  Serial.println("\td => Debug camera off");
  Serial.println("\t0 => Display PXP Rotation 0");
  Serial.println("\t1 => Display PXP Rotation 1");
  Serial.println("\t2 => Display PXP Rotation 2");
  Serial.println("\t3 => Display PXP Rotation 3");
  Serial.println("\t? => Show menu.");
 * Function that configures PXP for rotation, flip and scaling
 * and outputs to display.
 * rotation: 0 - 0 degrees, 1 - 90 degrees,
 *           2 - 180 degrees, 3 - 270 degrees
 * flip: false - no flip, true - flip.
 *       control in filp function PXP_flip, currently configured
 *       for horizontal flip.
 * scaling: scaling factor:
 *          To scale up by a factor of 4, the value of 1/4
 *          Follows inverse of factor input so for a scale
 *          factor of 1.5 actual scaling is about 67%
void PXP_ps_output(uint8_t rotation, bool flip, float scaling) {
  uint32_t psUlcX = 0;
  uint32_t psUlcY = 0;
  uint32_t psLrcX, psLrcY;
  if(image_width > image_height) {
    psLrcY = psUlcX + tft.width() - 1U;
    psLrcX = psUlcY + tft.height() - 1U;
  } else {
    psLrcX = psUlcX + tft.width() - 1U;
    psLrcY = psUlcY + tft.height() - 1U;
  uint32_t out_width, out_height;
  //memset((uint8_t *)d_fb, 0, sizeof_d_fb);
  PXP_input_background_color(0, 0, 153);
   * Configures the input buffer to image width and height.
  PXP_input_buffer(s_fb /* s_fb */, bytesperpixel_in, image_width, image_height);
   * sets the output format to RGB565
  // VYUY1P422, PXP_UYVY1P422
  PXP_input_format(PXP_Y8);
  //PXP_SetCsc1Mode(0);
  /* sets image corners                                       *
   * ULC: contains the upper left coordinate of the Processed Surface in the output
   * frame buffer (in pixels). Values that are within the PXP_OUT_LRC X,Y extents are
   * valid. The lowest valid value for these fields is 0,0. If the value of the
   * PXP_OUT_PS_ULC is greater than the PXP_OUT_LRC, then no PS pixels will be
   * fetched from memory, but only PXP_PS_BACKGROUND pixels will be processed by
   * the PS engine. Pixel locations that are greater than or equal to the PS upper left
   * coordinates, less than or equal to the PS lower right coordinates, and within the
   * PXP_OUT_LRC extents will use the PS to render pixels into the output buffer.
   * LRC:  contains the size, or lower right coordinate, of the output buffer NOT
   * rotated. It is implied that the upper left coordinate of the output surface is always [0,0].
   * When rotating the framebuffer, the PXP will automatically swap the X/Y, or WIDTH/HEIGHT
   * to accomodate the rotated size.
   * currently configured to match TFT width and height for rotation 0! Note the -1 used with
   * psUlcX and psUlcY - this is per the manual.
  PXP_input_position(psUlcX, psUlcY, psLrcX, psLrcY);  // need this to override the setup in pxp_input_buffer
  // Generic function to capture an image and put it in the source buffer
  capture_frame(false);
   * Configures the output buffer to image width and height.
   * width and height will be swapped depending on rotation.
  if (rotation == 1 || rotation == 3) {
    out_width = image_height;
    out_height = image_width;
  } else {
    out_width = image_width;
    out_height = image_height;
  PXP_output_buffer(d_fb, bytesperpixel_out, out_width, out_height);
  PXP_output_format(PXP_RGB565);
  // PXP_output_clip sets OUT_LRC register
  /* according to the RM:                                           *
   * The PXP generates an output image in the resolution programmed *
   * by the OUT_LRCregister.                                        *
   * If an image is 480x320, then the for a rotation of 0 you it has*
   * to be reversed to 320x480 since you drawing on a screen that is*
   * 320x480 for the ILI8488.
   *  has to be configured after the output buffer since library
   *  configures it based on the config specied
    PXP_output_clip(out_height - 1, out_width - 1);
  } else {
    PXP_output_clip(out_width - 1, out_height - 1);
  // Rotation
  /* Setting this bit to 1'b0 will place the rotationre sources at  *
   * the output stage of the PXP data path. Image compositing will  *
   * occur before pixels are processed for rotation.                *
   * Setting this bit to a 1'b1 will place the rotation resources   *
   * before image composition.                                      *
  PXP_rotate_position(0);
  Serial.println("Rotating");
  // Performs the actual rotation specified
  PXP_rotate(rotation);
  // flip - pretty straight forward
  PXP_flip(flip);
   * if performing scaling we call out to the scaling function
   * which will perform remaining scaling and send to display.
  if(scaling > 0.0f){
    PXP_scaling(scaling, out_width, out_height, rotation);
  } else {
    PXP_process();
    Serial.println("Drawing frame");
    draw_frame(out_width, out_height, d_fb);
void PXP_scaling(float downScaleFact, uint16_t width, uint16_t height, uint8_t rotation) {
  uint16_t IMG_WIDTH  = width;
  uint16_t IMG_HEIGHT = height;
  outputWidth = (uint16_t)((float)(IMG_WIDTH) / downScaleFact);
  outputHeight = (uint16_t)((float)(IMG_HEIGHT) / downScaleFact);
  //capture_frame(false);
  PXP_input_background_color(0, 153, 0);
  PXP_output_buffer(d_fb, bytesperpixel_out, outputWidth, outputHeight);
  if(rotation == 1 || rotation == 3) {
    PXP_output_clip( outputHeight - 1, outputWidth - 1);
  } else {
    PXP_output_clip( outputWidth - 1, outputHeight - 1);
  PXP_setScaling( IMG_WIDTH, IMG_HEIGHT, outputWidth, outputHeight);
  PXP_process();
  draw_frame(outputWidth, outputHeight, d_fb );
void PXP_flip(bool flip) {
  /* there are 3 flip commands that you can use           *
   * PXP_flip_vertically                                  *
   * PXP_flip_horizontally                                *
   * PXP_flip_both                                        *
  PXP_flip_both(flip);
michaelsmorto
Ok think I got it solved.
Was looking at this post: https://community.nxp.com/t5/i-MX-Processors/PXP-YUV-to-RGB-conversion/td-p/605613.  And playing a bit used the following settings:
HW_PXP_CSC1_COEF0 : 0x84ab01f0
HW_PXP_CSC1_COEF1 : 0
HW_PXP_CSC1_COEF2 : 0
and was able to get my grayscale image:
This is a qvga image that has been rotated and scaled to just about fit the ILI9488 screen (480x320)
Not sure if there is a better way.
michaelsmorto
%3CLINGO-SUB%20id%3D%22lingo-sub-1867474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMXRT1060%20Converting%20Monochrome%20to%20RGB565%20using%20PXP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1867474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWe%20are%20working%20with%202%20cameras%2C%20HM01B0%20and%20the%20HM0360%2C%20which%20only%20support%20Bayer%20or%20Monochrome%20formats.%26nbsp%3B%20So%20we%20have%20been%20using%20a%20monochrome%20pallet%20to%20convert%20to%20RGB565%20format.%26nbsp%3B%20We%20have%20been%20trying%20to%20use%20PXP%20to%20do%20the%20conversion%20with%20varying%20degrees%20of%20success.%3C%2FP%3E%3CP%3EFor%20instance%2C%20since%20the%20data%20is%208-bit%20monochrome%20we%20started%20with%20using%20Y8%20for%20the%20input%20buffer%20and%20RGB565%20as%20the%20output%20buffer.%26nbsp%3B%20While%20the%20image%20looks%20right%20its%20all%20RED%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22michaelsmorto_0-1715896071679.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22michaelsmorto_0-1715896071679.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F279199iF4FC88B20D0C5586%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22michaelsmorto_0-1715896071679.jpeg%22%20alt%3D%22michaelsmorto_0-1715896071679.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EIf%20we%20use%20one%20of%20YUV%20422%201p%20fomats%20as%20input%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22michaelsmorto_1-1715896131612.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22michaelsmorto_1-1715896131612.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F279200iA903234E48A4DF6B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22michaelsmorto_1-1715896131612.jpeg%22%20alt%3D%22michaelsmorto_1-1715896131612.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EWe%20get%202%20half%20images.%26nbsp%3B%20The%20camera%20is%20set%20to%20use%20QVGA%20format.%3CBR%20%2F%3E%3CBR%20%2F%3EAny%20suggestions%20would%20be%20helpful%20-%20or%20are%20we%20wasting%20our%20time.%3CBR%20%2F%3E%3CBR%20%2F%3EPS%26gt%3B%20Using%20a%20Teensy%204.1%20with%20PXP%20ported%20to%20work%20in%20an%20Arduino%20IDE.%26nbsp%3B%20Teensy%204.1%20is%20a%20IMXRT1062%20based%20MCU.%26nbsp%3B%20The%20sketch%20we%20use%20is%20as%20follows%20(the%20commands%20should%20be%20familar)%3A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23include%3C%2FSPAN%3E%20%3CSPAN%3E%22Camera.h%22%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23include%3C%2FSPAN%3E%20%3CSPAN%3E%22T4_PXP.h%22%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%2F************************************************%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%2F%2FSpecify%20the%20pins%20used%20for%20Non-SPI%20functions%20of%20display%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%2F%2F%23define%20TFT_DC%204%20%26nbsp%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%2F%2F%23define%20TFT_CS%205%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%2F%2F%23define%20TFT_RST%202%20%26nbsp%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20TFT_DC%20%3C%2FSPAN%3E%3CSPAN%3E9%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20TFT_CS%20%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20TFT_RST%20%3C%2FSPAN%3E%3CSPAN%3E8%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20use9488%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23if%3C%2FSPAN%3E%20%3CSPAN%3Edefined%3C%2FSPAN%3E%3CSPAN%3E(use9488)%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23include%3C%2FSPAN%3E%20%3CSPAN%3E%3CILI9488_T3.H%3E%3C%2FILI9488_T3.H%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3EILI9488_t3%20tft%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EILI9488_t3%3C%2FSPAN%3E%3CSPAN%3E(TFT_CS%2C%20TFT_DC%2C%20TFT_RST)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20TFT_BLACK%20ILI9488_BLACK%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20TFT_YELLOW%20ILI9488_YELLOW%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20TFT_RED%20ILI9488_RED%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20TFT_GREEN%20ILI9488_GREEN%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20TFT_BLUE%20ILI9488_BLUE%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20CENTER%20%3C%2FSPAN%3E%3CSPAN%3EILI9488_t3%3C%2FSPAN%3E%3CSPAN%3E%3A%3ACENTER%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23else%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23include%3C%2FSPAN%3E%20%3CSPAN%3E%3CILI9341_T3N.H%3E%3C%2FILI9341_T3N.H%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3EILI9341_t3n%20tft%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EILI9341_t3n%3C%2FSPAN%3E%3CSPAN%3E(TFT_CS%2C%20TFT_DC%2C%20TFT_RST)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20TFT_BLACK%20ILI9341_BLACK%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20TFT_YELLOW%20ILI9341_YELLOW%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20TFT_RED%20ILI9341_RED%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20TFT_GREEN%20ILI9341_GREEN%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20TFT_BLUE%20ILI9341_BLUE%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20CENTER%20%3C%2FSPAN%3E%3CSPAN%3EILI9341_t3n%3C%2FSPAN%3E%3CSPAN%3E%3A%3ACENTER%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23endif%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%2F************************************************%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23include%3C%2FSPAN%3E%20%3CSPAN%3E%22TMM_HM0360%2FHM0360.h%22%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3EHM0360%20himax%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3ECamera%3C%2FSPAN%3E%20%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ehimax%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20CameraID%20%3C%2FSPAN%3E%3CSPAN%3E0x0360%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20SCREEN_ROTATION%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20MIRROR_FLIP_CAMERA%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Eframesize_t%3C%2FSPAN%3E%3CSPAN%3E%20camera_framesize%20%3D%20FRAMESIZE_QVGA%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Ebool%3C%2FSPAN%3E%3CSPAN%3E%20useGPIO%20%3D%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%3CSPAN%3E%20bytesperpixel_in%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%3CSPAN%3E%20bytesperpixel_out%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Euint16_t%3C%2FSPAN%3E%3CSPAN%3E%20FRAME_HEIGHT%2C%20FRAME_WIDTH%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Ebool%3C%2FSPAN%3E%3CSPAN%3E%20pxpStarted%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Euint16_t%3C%2FSPAN%3E%3CSPAN%3E%20outputWidth%2C%20outputHeight%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%2F%2F%20Define%20Palette%20for%20Himax%20Cameras%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20MCP(%3C%2FSPAN%3E%3CSPAN%3Em%3C%2FSPAN%3E%3CSPAN%3E)%20(uint16_t)(((m%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3E0xF8%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E8%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3E%7C%3C%2FSPAN%3E%3CSPAN%3E%20((m%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3E0xFC%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3E%7C%3C%2FSPAN%3E%3CSPAN%3E%20(m%20%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Estatic%3C%2FSPAN%3E%20%3CSPAN%3Econst%3C%2FSPAN%3E%20%3CSPAN%3Euint16_t%3C%2FSPAN%3E%20%3CSPAN%3Emono_palette%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E256%3C%2FSPAN%3E%3CSPAN%3E%5D%20PROGMEM%20%3D%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x00%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x01%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x02%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x03%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x04%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x05%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x06%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x07%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x08%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x09%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x0a%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x0b%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x0c%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x0d%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x0e%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x0f%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x10%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x11%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x12%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x13%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x14%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x15%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x16%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x17%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x18%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x19%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x1a%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x1b%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x1c%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x1d%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x1e%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x1f%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x20%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x21%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x22%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x23%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x24%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x25%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x26%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x27%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x28%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x29%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x2a%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x2b%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x2c%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x2d%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x2e%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x2f%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x30%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x31%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x32%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x33%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x34%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x35%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x36%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x37%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x38%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x39%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x3a%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x3b%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x3c%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x3d%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x3e%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x3f%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x40%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x41%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x42%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x43%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x44%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x45%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x46%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x47%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x48%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x49%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x4a%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x4b%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x4c%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x4d%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x4e%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x4f%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x50%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x51%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x52%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x53%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x54%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x55%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x56%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x57%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x58%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x59%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x5a%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x5b%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x5c%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x5d%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x5e%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x5f%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x60%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x61%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x62%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x63%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x64%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x65%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x66%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x67%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x68%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x69%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x6a%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x6b%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x6c%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x6d%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x6e%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x6f%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x70%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x71%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x72%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x73%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x74%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x75%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x76%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x77%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x78%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x79%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x7a%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x7b%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x7c%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x7d%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x7e%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x7f%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x80%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x81%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x82%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x83%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x84%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x85%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x86%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x87%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x88%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x89%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x8a%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x8b%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x8c%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x8d%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x8e%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x8f%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x90%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x91%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x92%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x93%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x94%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x95%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x96%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x97%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x98%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x99%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x9a%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x9b%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x9c%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x9d%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x9e%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x9f%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xa0%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xa1%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xa2%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xa3%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xa4%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xa5%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xa6%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xa7%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xa8%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xa9%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xaa%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xab%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xac%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xad%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xae%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xaf%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xb0%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xb1%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xb2%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xb3%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xb4%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xb5%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xb6%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xb7%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xb8%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xb9%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xba%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xbb%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xbc%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xbd%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xbe%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xbf%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xc0%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xc1%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xc2%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xc3%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xc4%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xc5%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xc6%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xc7%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xc8%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xc9%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xca%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xcb%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xcc%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xcd%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xce%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xcf%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xd0%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xd1%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xd2%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xd3%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xd4%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xd5%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xd6%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xd7%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xd8%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xd9%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xda%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xdb%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xdc%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xdd%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xde%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xdf%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xe0%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xe1%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xe2%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xe3%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xe4%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xe5%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xe6%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xe7%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xe8%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xe9%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xea%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xeb%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xec%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xed%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xee%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xef%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xf0%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xf1%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xf2%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xf3%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xf4%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xf5%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xf6%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xf7%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xf8%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xf9%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xfa%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xfb%3C%2FSPAN%3E%3CSPAN%3E)%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xfc%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xfd%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xfe%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%3C%2FSPAN%3E%3CSPAN%3EMCP%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0xff%3C%2FSPAN%3E%3CSPAN%3E)%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%2F************************************************%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%3CSPAN%3E%20DMAMEM%20%3C%2FSPAN%3E%3CSPAN%3Es_fb%3C%2FSPAN%3E%3CSPAN%3E%5B(%3C%2FSPAN%3E%3CSPAN%3E480%3C%2FSPAN%3E%3CSPAN%3E)%20*%20%3C%2FSPAN%3E%3CSPAN%3E320%3C%2FSPAN%3E%3CSPAN%3E%5D%20%3C%2FSPAN%3E%3CSPAN%3E__attribute__%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3Ealigned%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E64%3C%2FSPAN%3E%3CSPAN%3E)))%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Euint16_t%3C%2FSPAN%3E%20%3CSPAN%3Ed_fb%3C%2FSPAN%3E%3CSPAN%3E%5B(%3C%2FSPAN%3E%3CSPAN%3E480%3C%2FSPAN%3E%3CSPAN%3E)%20*%20%3C%2FSPAN%3E%3CSPAN%3E320%3C%2FSPAN%3E%3CSPAN%3E%5D%20%3C%2FSPAN%3E%3CSPAN%3E__attribute__%3C%2FSPAN%3E%3CSPAN%3E%20((%3C%2FSPAN%3E%3CSPAN%3Ealigned%3C%2FSPAN%3E%3CSPAN%3E%20(%3C%2FSPAN%3E%3CSPAN%3E64%3C%2FSPAN%3E%3CSPAN%3E)))%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Econst%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20sizeof_s_fb%20%3D%20%3C%2FSPAN%3E%3CSPAN%3Esizeof%3C%2FSPAN%3E%3CSPAN%3E(s_fb)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Econst%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20sizeof_d_fb%20%3D%20%3C%2FSPAN%3E%3CSPAN%3Esizeof%3C%2FSPAN%3E%3CSPAN%3E(d_fb)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Euint16_t%3C%2FSPAN%3E%3CSPAN%3E%20%26nbsp%3Bimage_width%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Euint16_t%3C%2FSPAN%3E%3CSPAN%3E%20%26nbsp%3Bimage_height%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%2F************************************************%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3Esetup%3C%2FSPAN%3E%3CSPAN%3E()%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Ebegin%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E9600%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ewhile%3C%2FSPAN%3E%3CSPAN%3E%20(!Serial%20%26amp%3B%26amp%3B%20%3C%2FSPAN%3E%3CSPAN%3Emillis%3C%2FSPAN%3E%3CSPAN%3E()%20%26lt%3B%20%3C%2FSPAN%3E%3CSPAN%3E5000%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eif%3C%2FSPAN%3E%3CSPAN%3E%20(CrashReport)%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprint%3C%2FSPAN%3E%3CSPAN%3E(CrashReport)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22Press%20any%20key%20to%20continue%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ewhile%3C%2FSPAN%3E%3CSPAN%3E%20(%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eread%3C%2FSPAN%3E%3CSPAN%3E()%20!%3D%20-%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ewhile%3C%2FSPAN%3E%3CSPAN%3E%20(%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eread%3C%2FSPAN%3E%3CSPAN%3E()%20%3D%3D%20-%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ewhile%3C%2FSPAN%3E%3CSPAN%3E%20(%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eread%3C%2FSPAN%3E%3CSPAN%3E()%20!%3D%20-%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2F%20Start%20ILI9341%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Ebegin%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EsetRotation%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3CSPAN%3E%20%26nbsp%3B%2F%2F%20testing%20external%20rotation%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Etest_display%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Estart_camera%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20imagesize%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20imagesize%20%3D%20FRAME_WIDTH%20*%20FRAME_HEIGHT%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2FNote%20for%20rotation%200%20width%20and%20height%20reversed%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20image_width%20%3D%20FRAME_WIDTH%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20image_height%20%3D%20FRAME_HEIGHT%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EshowCommands%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Estart_pxp%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3Eloop%3C%2FSPAN%3E%3CSPAN%3E()%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eint%3C%2FSPAN%3E%3CSPAN%3E%20ch%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eif%3C%2FSPAN%3E%3CSPAN%3E%20(%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eavailable%3C%2FSPAN%3E%3CSPAN%3E())%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%3CSPAN%3E%20command%20%3D%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eread%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eswitch%3C%2FSPAN%3E%3CSPAN%3E%20(command)%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecase%3C%2FSPAN%3E%20%3CSPAN%3E'0'%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%20PXP%20rotation%200....%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_ps_output%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0.0f%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ebreak%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecase%3C%2FSPAN%3E%20%3CSPAN%3E'1'%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%20PXP%20rotation%201....%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_ps_output%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0.0f%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ebreak%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecase%3C%2FSPAN%3E%20%3CSPAN%3E'2'%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%20PXP%20rotation%202....%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_ps_output%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0.0f%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ebreak%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecase%3C%2FSPAN%3E%20%3CSPAN%3E'3'%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%20PXP%20rotation%203....%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_ps_output%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0.8f%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ebreak%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecase%3C%2FSPAN%3E%20%3CSPAN%3E'd'%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Edebug%3C%2FSPAN%3E%3CSPAN%3E(!%3C%2FSPAN%3E%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Edebug%3C%2FSPAN%3E%3CSPAN%3E())%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eif%3C%2FSPAN%3E%3CSPAN%3E%20(%3C%2FSPAN%3E%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Edebug%3C%2FSPAN%3E%3CSPAN%3E())%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22Camera%20Debug%20turned%20on%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%20%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22Camera%20debug%20turned%20off%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ebreak%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecase%3C%2FSPAN%3E%20%3CSPAN%3E'f'%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecapture_frame%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Etrue%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%2F%2Ftft.writeRect8BPP(0%2C%200%2C%20FRAME_WIDTH%2C%20FRAME_HEIGHT%2C%20s_fb%2C%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%2F%2F%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bmono_palette)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EsetRotation%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ebreak%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecase%3C%2FSPAN%3E%20%3CSPAN%3E's'%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22Starting%20PXP.....%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Estart_pxp%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ebreak%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecase%3C%2FSPAN%3E%20%3CSPAN%3E't'%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Etest_display%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ebreak%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecase%3C%2FSPAN%3E%20%3CSPAN%3E'%3F'%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EshowCommands%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Edefault%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ebreak%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3Estart_pxp%3C%2FSPAN%3E%3CSPAN%3E()%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_init%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ememset%3C%2FSPAN%3E%3CSPAN%3E(s_fb%2C%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2C%20sizeof_s_fb)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ememset%3C%2FSPAN%3E%3CSPAN%3E(d_fb%2C%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2C%20sizeof_d_fb)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20pxpStarted%20%3D%20%3C%2FSPAN%3E%3CSPAN%3Etrue%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3Edraw_frame%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Euint16_t%3C%2FSPAN%3E%20%3CSPAN%3Ewidth%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Euint16_t%3C%2FSPAN%3E%20%3CSPAN%3Eheight%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Econst%3C%2FSPAN%3E%20%3CSPAN%3Euint16_t%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3Ebuffer%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EwriteRect%3C%2FSPAN%3E%3CSPAN%3E(CENTER%2C%20CENTER%2C%20width%2C%20height%2C%20buffer%20)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3Ecapture_frame%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ebool%3C%2FSPAN%3E%20%3CSPAN%3Eshow_debug_info%3C%2FSPAN%3E%3CSPAN%3E)%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ememset%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%3CSPAN%3E%20*)s_fb%2C%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Esizeof%3C%2FSPAN%3E%3CSPAN%3E(s_fb))%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EsetMode%3C%2FSPAN%3E%3CSPAN%3E(HIMAX_MODE_STREAMING_NFRAMES%2C%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EuseDMA%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EreadFrame%3C%2FSPAN%3E%3CSPAN%3E(s_fb%20%2C%20sizeof_s_fb)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Earm_dcache_flush%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%3CSPAN%3E*)s_fb%2C%20sizeof_s_fb)%3B%3C%2FSPAN%3E%3CSPAN%3E%20%2F%2F%20always%20flush%20cache%20after%20writing%20to%20DMAMEM%20variable%20that%20will%20be%20accessed%20by%20DMA%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22Finished%20reading%20frame%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%20%26nbsp%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3Estart_camera%3C%2FSPAN%3E%3CSPAN%3E()%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2F%20Setup%20for%20OV5640%20Camera%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2F%20CSI%20support%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EpinMode%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%2C%20OUTPUT)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EpinMode%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%2C%20OUTPUT)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%3CSPAN%3E%20reset_pin%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E14%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%3CSPAN%3E%20powdwn_pin%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E15%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EpinMode%3C%2FSPAN%3E%3CSPAN%3E(powdwn_pin%2C%20INPUT)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EpinMode%3C%2FSPAN%3E%3CSPAN%3E(reset_pin%2C%20INPUT_PULLUP)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%3CSPAN%3E%20status%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2Fcamera.setPins(29%2C%2010%2C%2033%2C%2032%2C%2031%2C%2040%2C%2041%2C%2042%2C%2043)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20status%20%3D%20%3C%2FSPAN%3E%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Ebegin%3C%2FSPAN%3E%3CSPAN%3E(camera_framesize%2C%20%3C%2FSPAN%3E%3CSPAN%3E15%3C%2FSPAN%3E%3CSPAN%3E%2C%20useGPIO)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EsetPixformat%3C%2FSPAN%3E%3CSPAN%3E(YUV422)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintf%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22Begin%20status%3A%20%3C%2FSPAN%3E%3CSPAN%3E%25d%3C%2FSPAN%3E%3CSPAN%3E%5Cn%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20status)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eif%3C%2FSPAN%3E%3CSPAN%3E%20(!status)%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22Camera%20failed%20to%20start%20-%20try%20reset!!!%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%2F%2FSerial.printf(%22%5CtPin%2030%3A%25u%2031%3A%25u%5Cn%22%2C%20digitalReadFast(30)%2C%20digitalReadFast(31))%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintf%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%5Ct%3C%2FSPAN%3E%3CSPAN%3EPin%20rst(%3C%2FSPAN%3E%3CSPAN%3E%25u%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FSPAN%3E%3CSPAN%3E%25u%3C%2FSPAN%3E%3CSPAN%3E%20PowDn(%3C%2FSPAN%3E%3CSPAN%3E%25u%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FSPAN%3E%3CSPAN%3E%25u%3C%2FSPAN%3E%3CSPAN%3E%5Cn%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20reset_pin%2C%20%3C%2FSPAN%3E%3CSPAN%3EdigitalRead%3C%2FSPAN%3E%3CSPAN%3E(reset_pin)%2C%20powdwn_pin%2C%20%3C%2FSPAN%3E%3CSPAN%3EdigitalRead%3C%2FSPAN%3E%3CSPAN%3E(powdwn_pin))%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EpinMode%3C%2FSPAN%3E%3CSPAN%3E(reset_pin%2C%20OUTPUT)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EdigitalWriteFast%3C%2FSPAN%3E%3CSPAN%3E(reset_pin%2C%20LOW)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Edelay%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E500%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EpinMode%3C%2FSPAN%3E%3CSPAN%3E(reset_pin%2C%20INPUT_PULLUP)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Edelay%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E500%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20status%20%3D%20%3C%2FSPAN%3E%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Ebegin%3C%2FSPAN%3E%3CSPAN%3E(camera_framesize%2C%20%3C%2FSPAN%3E%3CSPAN%3E15%3C%2FSPAN%3E%3CSPAN%3E%2C%20useGPIO)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eif%3C%2FSPAN%3E%3CSPAN%3E%20(!status)%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22Camera%20failed%20to%20start%20again%20program%20halted%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ewhile%3C%2FSPAN%3E%3CSPAN%3E%20(%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22Camera%20settings%3A%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprint%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%5Ct%3C%2FSPAN%3E%3CSPAN%3Ewidth%20%3D%20%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Ewidth%3C%2FSPAN%3E%3CSPAN%3E())%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprint%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%5Ct%3C%2FSPAN%3E%3CSPAN%3Eheight%20%3D%20%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eheight%3C%2FSPAN%3E%3CSPAN%3E())%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2FSerial.print(%22%5Ctbits%20per%20pixel%20%3D%20NA%22)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2FSerial.println(camera.bitsPerPixel())%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintf%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22TFT%20Width%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E%25u%3C%2FSPAN%3E%3CSPAN%3E%20Height%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E%25u%3C%2FSPAN%3E%3CSPAN%3E%5Cn%5Cn%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Ewidth%3C%2FSPAN%3E%3CSPAN%3E()%2C%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eheight%3C%2FSPAN%3E%3CSPAN%3E())%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20FRAME_HEIGHT%20%3D%20%3C%2FSPAN%3E%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eheight%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20FRAME_WIDTH%20%3D%20%3C%2FSPAN%3E%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Ewidth%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintf%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22ImageSize%20(w%2Ch)%3A%20%3C%2FSPAN%3E%3CSPAN%3E%25d%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%25d%3C%2FSPAN%3E%3CSPAN%3E%5Cn%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20FRAME_WIDTH%2C%20FRAME_HEIGHT)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2F%20Lets%20setup%20camera%20interrupt%20priorities%3A%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2F%20camera.setVSyncISRPriority(102)%3B%20%2F%2F%20higher%20priority%20than%20default%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EsetDMACompleteISRPriority%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E192%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3CSPAN%3E%20%2F%2F%20lower%20than%20default%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecamera%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EsetMode%3C%2FSPAN%3E%3CSPAN%3E(HIMAX_MODE_STREAMING%2C%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3CSPAN%3E%20%2F%2F%20turn%20on%2C%20continuous%20streaming%20mode%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3Etest_display%3C%2FSPAN%3E%3CSPAN%3E()%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EsetRotation%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EfillScreen%3C%2FSPAN%3E%3CSPAN%3E(TFT_RED)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Edelay%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E500%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EfillScreen%3C%2FSPAN%3E%3CSPAN%3E(TFT_GREEN)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Edelay%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E500%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EfillScreen%3C%2FSPAN%3E%3CSPAN%3E(TFT_BLUE)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Edelay%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E500%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EfillScreen%3C%2FSPAN%3E%3CSPAN%3E(TFT_BLACK)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Edelay%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E500%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EsetRotation%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EshowCommands%3C%2FSPAN%3E%3CSPAN%3E()%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%5Cn%3C%2FSPAN%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%26nbsp%3BCommand%20List%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%5Ct%3C%2FSPAN%3E%3CSPAN%3Es%20%3D%26gt%3B%20Start%20PXP%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%5Ct%3C%2FSPAN%3E%3CSPAN%3Ef%20%3D%26gt%3B%20Capture%20normal%20frame%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%5Ct%3C%2FSPAN%3E%3CSPAN%3Et%20%3D%26gt%3B%20Test%20display%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%5Ct%3C%2FSPAN%3E%3CSPAN%3Ed%20%3D%26gt%3B%20Debug%20camera%20off%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%5Ct%3C%2FSPAN%3E%3CSPAN%3E0%20%3D%26gt%3B%20Display%20PXP%20Rotation%200%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%5Ct%3C%2FSPAN%3E%3CSPAN%3E1%20%3D%26gt%3B%20Display%20PXP%20Rotation%201%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%5Ct%3C%2FSPAN%3E%3CSPAN%3E2%20%3D%26gt%3B%20Display%20PXP%20Rotation%202%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%5Ct%3C%2FSPAN%3E%3CSPAN%3E3%20%3D%26gt%3B%20Display%20PXP%20Rotation%203%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%5Ct%3C%2FSPAN%3E%3CSPAN%3E%3F%20%3D%26gt%3B%20Show%20menu.%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%2F**************************************************************%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B*%20Function%20that%20configures%20PXP%20for%20rotation%2C%20flip%20and%20scaling%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B*%20and%20outputs%20to%20display.%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B*%20rotation%3A%200%20-%200%20degrees%2C%201%20-%2090%20degrees%2C%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B*%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%202%20-%20180%20degrees%2C%203%20-%20270%20degrees%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B*%20flip%3A%20false%20-%20no%20flip%2C%20true%20-%20flip.%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B*%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20control%20in%20filp%20function%20PXP_flip%2C%20currently%20configured%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B*%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20for%20horizontal%20flip.%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B*%20scaling%3A%20scaling%20factor%3A%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B*%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BTo%20scale%20up%20by%20a%20factor%20of%204%2C%20the%20value%20of%201%2F4%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B*%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BFollows%20inverse%20of%20factor%20input%20so%20for%20a%20scale%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B*%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bfactor%20of%201.5%20actual%20scaling%20is%20about%2067%25%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B***************************************************************%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EPXP_ps_output%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3Erotation%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Ebool%3C%2FSPAN%3E%20%3CSPAN%3Eflip%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Efloat%3C%2FSPAN%3E%20%3CSPAN%3Escaling%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20psUlcX%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20psUlcY%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20psLrcX%2C%20psLrcY%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eif%3C%2FSPAN%3E%3CSPAN%3E(image_width%20%26gt%3B%20image_height)%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20psLrcY%20%3D%20psUlcX%20%2B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Ewidth%3C%2FSPAN%3E%3CSPAN%3E()%20-%20%3C%2FSPAN%3E%3CSPAN%3E1U%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20psLrcX%20%3D%20psUlcY%20%2B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eheight%3C%2FSPAN%3E%3CSPAN%3E()%20-%20%3C%2FSPAN%3E%3CSPAN%3E1U%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%20%3C%2FSPAN%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20psLrcX%20%3D%20psUlcX%20%2B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Ewidth%3C%2FSPAN%3E%3CSPAN%3E()%20-%20%3C%2FSPAN%3E%3CSPAN%3E1U%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20psLrcY%20%3D%20psUlcY%20%2B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eheight%3C%2FSPAN%3E%3CSPAN%3E()%20-%20%3C%2FSPAN%3E%3CSPAN%3E1U%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20out_width%2C%20out_height%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2Fmemset((uint8_t%20*)d_fb%2C%200%2C%20sizeof_d_fb)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EfillScreen%3C%2FSPAN%3E%3CSPAN%3E(TFT_BLACK)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_input_background_color%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E153%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F*************************************************************%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20Configures%20the%20input%20buffer%20to%20image%20width%20and%20height.%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B**************************************************************%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_input_buffer%3C%2FSPAN%3E%3CSPAN%3E(s_fb%3C%2FSPAN%3E%3CSPAN%3E%20%2F*%20s_fb%20*%2F%3C%2FSPAN%3E%3CSPAN%3E%2C%20bytesperpixel_in%2C%20image_width%2C%20image_height)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F**************************************************************%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20sets%20the%20output%20format%20to%20RGB565%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B****************************************************************%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2F%20VYUY1P422%2C%20PXP_UYVY1P422%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_input_format%3C%2FSPAN%3E%3CSPAN%3E(PXP_Y8)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2FPXP_SetCsc1Mode(0)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F*%20sets%20image%20corners%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20ULC%3A%20contains%20the%20upper%20left%20coordinate%20of%20the%20Processed%20Surface%20in%20the%20output%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20frame%20buffer%20(in%20pixels).%20Values%20that%20are%20within%20the%20PXP_OUT_LRC%20X%2CY%20extents%20are%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20valid.%20The%20lowest%20valid%20value%20for%20these%20fields%20is%200%2C0.%20If%20the%20value%20of%20the%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20PXP_OUT_PS_ULC%20is%20greater%20than%20the%20PXP_OUT_LRC%2C%20then%20no%20PS%20pixels%20will%20be%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20fetched%20from%20memory%2C%20but%20only%20PXP_PS_BACKGROUND%20pixels%20will%20be%20processed%20by%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20the%20PS%20engine.%20Pixel%20locations%20that%20are%20greater%20than%20or%20equal%20to%20the%20PS%20upper%20left%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20coordinates%2C%20less%20than%20or%20equal%20to%20the%20PS%20lower%20right%20coordinates%2C%20and%20within%20the%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20PXP_OUT_LRC%20extents%20will%20use%20the%20PS%20to%20render%20pixels%20into%20the%20output%20buffer.%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20LRC%3A%20%26nbsp%3Bcontains%20the%20size%2C%20or%20lower%20right%20coordinate%2C%20of%20the%20output%20buffer%20NOT%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20rotated.%20It%20is%20implied%20that%20the%20upper%20left%20coordinate%20of%20the%20output%20surface%20is%20always%20%5B0%2C0%5D.%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20When%20rotating%20the%20framebuffer%2C%20the%20PXP%20will%20automatically%20swap%20the%20X%2FY%2C%20or%20WIDTH%2FHEIGHT%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20to%20accomodate%20the%20rotated%20size.%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20currently%20configured%20to%20match%20TFT%20width%20and%20height%20for%20rotation%200!%20Note%20the%20-1%20used%20with%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20psUlcX%20and%20psUlcY%20-%20this%20is%20per%20the%20manual.%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_input_position%3C%2FSPAN%3E%3CSPAN%3E(psUlcX%2C%20psUlcY%2C%20psLrcX%2C%20psLrcY)%3B%3C%2FSPAN%3E%3CSPAN%3E%20%26nbsp%3B%2F%2F%20need%20this%20to%20override%20the%20setup%20in%20pxp_input_buffer%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2F%20Generic%20function%20to%20capture%20an%20image%20and%20put%20it%20in%20the%20source%20buffer%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ecapture_frame%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F*************************************************************%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20Configures%20the%20output%20buffer%20to%20image%20width%20and%20height.%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20width%20and%20height%20will%20be%20swapped%20depending%20on%20rotation.%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B**************************************************************%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eif%3C%2FSPAN%3E%3CSPAN%3E%20(rotation%20%3D%3D%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20%7C%7C%20rotation%20%3D%3D%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20out_width%20%3D%20image_height%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20out_height%20%3D%20image_width%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%20%3C%2FSPAN%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20out_width%20%3D%20image_width%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20out_height%20%3D%20image_height%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_output_buffer%3C%2FSPAN%3E%3CSPAN%3E(d_fb%2C%20bytesperpixel_out%2C%20out_width%2C%20out_height)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F**************************************************************%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20sets%20the%20output%20format%20to%20RGB565%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B****************************************************************%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_output_format%3C%2FSPAN%3E%3CSPAN%3E(PXP_RGB565)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2F%20PXP_output_clip%20sets%20OUT_LRC%20register%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F*%20according%20to%20the%20RM%3A%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20The%20PXP%20generates%20an%20output%20image%20in%20the%20resolution%20programmed%20*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20by%20the%20OUT_LRCregister.%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20If%20an%20image%20is%20480x320%2C%20then%20the%20for%20a%20rotation%20of%200%20you%20it%20has*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20to%20be%20reversed%20to%20320x480%20since%20you%20drawing%20on%20a%20screen%20that%20is*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20320x480%20for%20the%20ILI8488.%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20%26nbsp%3Bhas%20to%20be%20configured%20after%20the%20output%20buffer%20since%20library%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20%26nbsp%3Bconfigures%20it%20based%20on%20the%20config%20specied%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B******************************************************************%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eif%3C%2FSPAN%3E%3CSPAN%3E%20(rotation%20%3D%3D%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20%7C%7C%20rotation%20%3D%3D%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_output_clip%3C%2FSPAN%3E%3CSPAN%3E(out_height%20-%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20out_width%20-%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%20%3C%2FSPAN%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_output_clip%3C%2FSPAN%3E%3CSPAN%3E(out_width%20-%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20out_height%20-%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2F%20Rotation%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F*%20Setting%20this%20bit%20to%201'b0%20will%20place%20the%20rotationre%20sources%20at%20%26nbsp%3B*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20the%20output%20stage%20of%20the%20PXP%20data%20path.%20Image%20compositing%20will%20%26nbsp%3B*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20occur%20before%20pixels%20are%20processed%20for%20rotation.%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20Setting%20this%20bit%20to%20a%201'b1%20will%20place%20the%20rotation%20resources%20%26nbsp%3B%20*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20before%20image%20composition.%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_rotate_position%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22Rotating%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2F%20Performs%20the%20actual%20rotation%20specified%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_rotate%3C%2FSPAN%3E%3CSPAN%3E(rotation)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2F%20flip%20-%20pretty%20straight%20forward%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_flip%3C%2FSPAN%3E%3CSPAN%3E(flip)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F************************************************************%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20if%20performing%20scaling%20we%20call%20out%20to%20the%20scaling%20function%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20which%20will%20perform%20remaining%20scaling%20and%20send%20to%20display.%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B************************************************************%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eif%3C%2FSPAN%3E%3CSPAN%3E(scaling%20%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3E0.0f%3C%2FSPAN%3E%3CSPAN%3E)%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_scaling%3C%2FSPAN%3E%3CSPAN%3E(scaling%2C%20out_width%2C%20out_height%2C%20rotation)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%20%3C%2FSPAN%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_process%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESerial%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3Eprintln%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22Drawing%20frame%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Edraw_frame%3C%2FSPAN%3E%3CSPAN%3E(out_width%2C%20out_height%2C%20d_fb)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EPXP_scaling%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Efloat%3C%2FSPAN%3E%20%3CSPAN%3EdownScaleFact%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Euint16_t%3C%2FSPAN%3E%20%3CSPAN%3Ewidth%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Euint16_t%3C%2FSPAN%3E%20%3CSPAN%3Eheight%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3Erotation%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Euint16_t%3C%2FSPAN%3E%3CSPAN%3E%20IMG_WIDTH%20%26nbsp%3B%3D%20width%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Euint16_t%3C%2FSPAN%3E%3CSPAN%3E%20IMG_HEIGHT%20%3D%20height%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20outputWidth%20%3D%20(%3C%2FSPAN%3E%3CSPAN%3Euint16_t%3C%2FSPAN%3E%3CSPAN%3E)((%3C%2FSPAN%3E%3CSPAN%3Efloat%3C%2FSPAN%3E%3CSPAN%3E)(IMG_WIDTH)%20%2F%20downScaleFact)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20outputHeight%20%3D%20(%3C%2FSPAN%3E%3CSPAN%3Euint16_t%3C%2FSPAN%3E%3CSPAN%3E)((%3C%2FSPAN%3E%3CSPAN%3Efloat%3C%2FSPAN%3E%3CSPAN%3E)(IMG_HEIGHT)%20%2F%20downScaleFact)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F%2Fcapture_frame(false)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_input_background_color%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E153%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_output_buffer%3C%2FSPAN%3E%3CSPAN%3E(d_fb%2C%20bytesperpixel_out%2C%20outputWidth%2C%20outputHeight)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eif%3C%2FSPAN%3E%3CSPAN%3E(rotation%20%3D%3D%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20%7C%7C%20rotation%20%3D%3D%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_output_clip%3C%2FSPAN%3E%3CSPAN%3E(%20outputHeight%20-%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20outputWidth%20-%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%20%3C%2FSPAN%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_output_clip%3C%2FSPAN%3E%3CSPAN%3E(%20outputWidth%20-%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20outputHeight%20-%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_setScaling%3C%2FSPAN%3E%3CSPAN%3E(%20IMG_WIDTH%2C%20IMG_HEIGHT%2C%20outputWidth%2C%20outputHeight)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_process%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Etft%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EfillScreen%3C%2FSPAN%3E%3CSPAN%3E(TFT_GREEN)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Edraw_frame%3C%2FSPAN%3E%3CSPAN%3E(outputWidth%2C%20outputHeight%2C%20d_fb%20)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EPXP_flip%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ebool%3C%2FSPAN%3E%20%3CSPAN%3Eflip%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%2F*%20there%20are%203%20flip%20commands%20that%20you%20can%20use%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20PXP_flip_vertically%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20PXP_flip_horizontally%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%20PXP_flip_both%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EPXP_flip_both%3C%2FSPAN%3E%3CSPAN%3E(flip)%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1867474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MXRT%20106x%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IMXRT1060%20Converting%20Monochrome%20to%20RGB565%20using%20PXP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOk%20think%20I%20got%20it%20solved.%26nbsp%3B%3C%2FP%3E%3CP%3EWas%20looking%20at%20this%20post%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FPXP-YUV-to-RGB-conversion%2Ftd-p%2F605613%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FPXP-YUV-to-RGB-conversion%2Ftd-p%2F605613%3C%2FA%3E.%26nbsp%3B%20And%20playing%20a%20bit%20used%20the%20following%20settings%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EHW_PXP_CSC1_COEF0%20%3A%200x84ab01f0%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EHW_PXP_CSC1_COEF1%20%3A%200%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EHW_PXP_CSC1_COEF2%20%3A%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eand%20was%20able%20to%20get%20my%20grayscale%20image%3A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22michaelsmorto_1-1715950393680.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22michaelsmorto_1-1715950393680.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F279399iEF0839EA8CC9DFBA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22michaelsmorto_1-1715950393680.jpeg%22%20alt%3D%22michaelsmorto_1-1715950393680.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThis%20is%20a%20qvga%20image%20that%20has%20been%20rotated%20and%20scaled%20to%20just%20about%20fit%20the%20ILI9488%20screen%20(480x320)%3C%2FP%3E%3CP%3ENot%20sure%20if%20there%20is%20a%20better%20way.%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
