IMXRT1050 rom memory map issue
1,760 次查看
MINGZ
hi,
I'm recently working on iMXRT1050EVKB and i found out that address 00200000-00217fff is shown reserved in the file IMXRT1050 reference manual.
But, it's a memory space for ROMCP(bootrom i guess) in other materials i found on some tutorials.
So i got bit confused which one is right? and if the file is right, where should be it's ROM space?
1,755 次查看
jeremyzhou
Hi @MINGZ ,
In the early version of the RM, it illustrates the memory space for the ROM code, however, it's removed in the recent version to avoid confusing the customers.
TIC
1,756 次查看
jeremyzhou
Hi @MINGZ ,
TIC
1,747 次查看
MINGZ
Thanks a lot, BTW how does its exsitence become a confusion?
