IMXRT1050-EVKB board debug download error
1,802件の閲覧回数
li57752009
Trying to download new code in the IMXRT1050-EVKB board
This was normal until this error occurred
Display the following information:
Unable to connect wire for probe index 1.
Error: Wire Ack Fault - target connected?
捕获.PNGat com.nxp.mcuxpresso.core.debug.support.linkserver.redlink.client.RedlinkServerClient.checkServerReply(RedlinkServerClient.java:214)
at com.nxp.mcuxpresso.core.debug.support.linkserver.redlink.client.RedlinkServerClient.wireConnect(RedlinkServerClient.java:1155)
at com.nxp.mcuxpresso.core.debug.support.linkserver.emulators.jtag.AbstractJtagDiscovery.ideConnect(AbstractJtagDiscovery.java:207)
at com.nxp.mcuxpresso.core.debug.support.linkserver.emulators.jtag.AbstractJtagDiscovery.connect(AbstractJtagDiscovery.java:187)
at com.nxp.mcuxpresso.core.debug.support.linkserver.emulators.jtag.AbstractJtagDiscovery.discover(AbstractJtagDiscovery.java:146)
at com.nxp.mcuxpresso.core.debug.support.linkserver.emulators.TargetDiscovery.jtagDiscovery(TargetDiscovery.java:457)
at com.nxp.mcuxpresso.core.debug.support.linkserver.launch.LaunchScriptUtils.getEmulatorInfo(LaunchScriptUtils.java:248)
at com.nxp.mcuxpresso.core.debug.support.linkserver.launch.LaunchScriptUtils.init(LaunchScriptUtils.java:488)
at com.nxp.mcuxpresso.core.debug.support.linkserver.launch.LaunchScriptUtils.<init>(LaunchScriptUtils.java:156)
at com.nxp.mcuxpresso.core.debug.support.linkserver.launch.LaunchScriptUtils.<init>(LaunchScriptUtils.java:143)
at com.nxp.mcuxpresso.core.debug.support.linkserver.services.TargetDiscoveryService.getTargetDiscovery(TargetDiscoveryService.java:138)
at com.nxp.mcuxpresso.core.debug.support.linkserver.override.LSFinalLaunchSequence$TargetDiscoveryJob.run(LSFinalLaunchSequence.java:110)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
4 返答(返信)
1,646件の閲覧回数
oswaldo-153
any solution for this situation?, i have the same board, i´m working on mcuxpresso 11.3
1,779件の閲覧回数
kerryzhou
Hi li57752009,
  Sorry for my later reply.
   Please follow me to try to erase the external flash at first.
   Your U3 module is controlled by the EN pin which is the PMIC_ON_REQ, it is the RT1052 PMIC_ON_REQ pin.
  So, now, you need to erase the external flash at first, then you should can debug your board again.
   I suggest you download the SDK led_blinky project after the external flash is erased.
  1. Download the MCUBootUtility tool from this link:
https://github.com/JayHeng/NXP-MCUBootUtility/archive/v2.4.0.zip
the related user manual is:
2. Let your MIMXRT1050-EVKB board enter the serial download mode.
   SW7 1-OFF, 2-OFF, 3-OFF, 4-ON
  Power off and power on the board again
3. User the MCUBOOTUtility tool to connect your board
   and erase it.
After you erase it, then you can reset the chip, and use your IDE download the code again.
Please try it on your side.
If you still have questions about it, please kindly let me know.
Kerry
1,800件の閲覧回数
li57752009
Error message:
1,792件の閲覧回数
li57752009
I find DCDC_3V3 short circuited to the ground
But I don't know exactly which short-circuited to the ground
