In this topic (related video) Mark demonstrate using HSGPIO on 106x. I see in device datasheet and reference manual system block diagram that 1010 also have HSGPIO under CM7 domain...
... but can't find anything related to HSGPIO in 1010 reference manual.
Solved! Go to Solution.
Hi @jh0 , according with this Application Note https://www.nxp.com/docs/en/application-note/AN12446.pdf on point 3.2 it explains that the RT1010 provides 29 channels of High-speed GPIO.
Best Regards
Best Regards
