I want to use an external clock for a PWM signal. I understand that this external clock will be routed through XBAR, and in my case XBAR1_OUT48 is connected to FLEXPWM2_EXT_CLK.
However what is the maximum frequency I can drive FLEXPWMn_EXT_CLK. Is it stated in any documentation?
best regards
KL
Solved! Go to Solution.
Hi @kinlee
I would like to apologize for the delay. We are overloaded on the request these days. I really really appreciate that you were so patient.
Regarding your question about the EXT_CLK for FlexPWM2, after double-checking internally, this external clock only can reach to the half of internal ipg_clock, that its default is 150MHz, so the maximum frequency you can drive on FLEXPWMn_EXT_CLK is 75MHz. Sadly, It is not stated in any public documentation.
Please let me know if you have more questions.
Best Regards.
Pablo Avalos.
Hi @kinlee
Best Regards.
Pablo Avalos.
