I have an IMX RT-1060 EVK board. I wanted to early initialize SDRAM for loading application image on it. I took the initialization sequence in the SEMC driver example as reference and wrote similar initialization code for my board. After initialization I have noticed that it is writing the memory for first 1 MB correctly but after that the CPU crashes and core dump comes up on serial. I am a novice developer so I am learning stuff. Can anyone please guide me what to do at this stage?
Note: I have checked that I am initializing base register BR0 correctly and I am selecting 32 MB in Memory Size (MS) section.
Solved! Go to Solution.
This issue has been resolved. I was not correctly configuring memory size as suspected.
