IMRT1176 Boot from flexspi1 secondary pins
wangdabing
Hello nxp support ,
      In our project ,we  use imxrt1176 flexspi1 secondary pin group to connect a winbond  W25Q128FVSIG flash , but i can not boot ,every power on , the mcu enters serial download mode . i have burned the BT_FUSE_SEL ,SECONDARY GROUP , and i have got the rom log  by blhost  as follows,
and the FDCB i used as follows:
wangdabing
please to see the attachement for schemetic .and  also help me to check the sdram part of the schemetic.
jeremyzhou
Thanks for your reply and clarification.
Firstly, after going through the schematic, I don't find any error with the QSPI connection.
Next, please follow the figure to check the eFuse setting.
Lastly, I'd like to suggest you use the MCUBootUtilitytool for testing.
TIC
jeremyzhou
Before giving some advice, I was wondering if you can share the schematic of the customize board.
TIC
