I want to change language in sln_svui_lot_local_demo.
yelin
I'm currently using VIT in sln voice solution and I'm using voice detect in Korean, but I want to change it from Shell to Changelang in English and use it in English.
diego_charles
Hi @yelin
My apologies for the delayed response.
I understand that you typed the changelang command from the terminal to set English
Are you still unable to use English? If so could you let me know more about your setup steps? Do you want more specific instructions? For example, I can help on that with detailed instructions to set a English model but by editing source code.
Diego
yelin
I've seen in the log that the VIT changed the language to changelang and saved in flash memory, but when I reboot the device, the language change is not maintained and it returns to the Default language that I set.
diego_charles
Hi @yelin
Thank you for the additional details.
I have some material that can be of help for you, it is related to setting language over source code. But I need to share it over email in a support ticket.  Could you help me to create a ticket in our support portal and make reference to this thread? Else I can help you creating a ticket.
Thank you for your patience.
Diego.
diego_charles
Hi @yelin
As a follow up, I already created a support  ticket, for you, and attached the presentation there. Just check your email regarding case 00648695.
Feel free to take a look and let me know if you are still getting issues, by replying to this thread or in the ticket, or if you get issues to see the material.
Thank you,
Diego
yelin
Currently, I am not using DSMT but using VIT to make changes.
Can VIT only replace two languages?
As shown in the picture above, if you set only 2 languages, the language will be changed, but if you set 3 languages, VIT Process error 2 will occur in the last language.
@diego_charles
