How to use SDRAM in secure FOTA function of Secure Bootloader(SBL)?
1,772 次查看
CainePark
I'm trying to implement secure FOTA using Secure Bootloader(SBL) & Secure Firmware(SFW).
I referenced '7.4 Secure FOTA' in MCUOTASBLSFWUG.pdf.
In the guide, when I check 'Enable ROM to verify sbl' , 'XIP_BOOT_HEADER_ENABLE' value is set to 0.
So I can't use SDRAM function.
I don't know the reason why the 'Secure FOTA' function disable the SDRAM function.
Please let me know how to use SDRAM function in 'Secure FOTA'.
标记 (3)
1,687 次查看
CainePark
I applied the example you provided and confirmed that SDRAM access worked normally after secure booting.
Thank you for your help!
1,736 次查看
GottiLuca
I've faced the same situation and the simplest solution I've found was to initialize the SDRAM "manually" by a function.
You can use as a reference the code in NXP SDK : i.e. : <sdk_root>\boards\evkmimxrt1064\driver_examples\semc\sdram .
In particular see the function BOARD_InitSEMC() in file semc_sdram.c .
1,688 次查看
CainePark
