I have to port the provided USB-Stack to use with CMX-RTOS for our projects. Is there any documentation on how to do that? I can't find any Application Note and the documentation provided with the USB-Stack is not very helpful either. Has anyone ported the Stack to any other RTOS and can give me some information where I have to change/implement what?
Kind regards,
Stefan
解決済! 解決策の投稿を見る。
Hello Stefan,
Unfortunately, we don't have such type of documentation, sorry for the inconvenience that this might cause you.
Victor
Hello Stefan,
Unfortunately, we don't have any documentation that explains how to port the USB stack to CMX-RTOS. I suggest you contact CMX Systems support to see if they have any documentation regarding this.
Victor
Thank you for your answer Victor,
do you have any documentation of the USB-Stack which explains which parts depend on any RTOS (e.g. how was the bare metal usb stack ported for the provided FreeRTOS)? That would already be a lot of help to identify wich part of the stack needs to be modified.
Kind regards,
Stefan
Hello Stefan,
Victor
