How to modify the example code of RT1060 SDK to compiler the FW that was run on SDRAM
JarvisC
Hi All,
The default example code in the RT1060 SDK was compiler the FW that was run on BOARD_FLASH.
ex: evkmimxrt1060_hello_world /evkmimxrt1060_iled_blinky / evkmimxrt1060_shell ...etc
What should I modify in the SDK example code to run it on SDRAM?
Please help to share the information.
Thanks.
kerryzhou
Hi @JarvisC ,
   Thank you for your interest in the NXP MIMXRT product, I would like to provide service for you.
  You can refer to my doc:
https://community.nxp.com/t5/i-MX-RT-Knowledge-Base/RT1050-SDRAM-app-code-boot-from-SDcard-burn-with...
chapter 2 RT1050 SDRAM app image generation
Then the code will run from the SDRAM.
Wish it helps you!
Kerry
