Hi All,
The default example code in the RT1060 SDK was compiler the FW that was run on BOARD_FLASH.
ex: evkmimxrt1060_hello_world /evkmimxrt1060_iled_blinky / evkmimxrt1060_shell ...etc
What should I modify in the SDK example code to run it on SDRAM?
Please help to share the information.
Thanks.
Hi @JarvisC ,
Thank you for your interest in the NXP MIMXRT product, I would like to provide service for you.
You can refer to my doc:
chapter 2 RT1050 SDRAM app image generation
Then the code will run from the SDRAM.
Wish it helps you!
Kerry
