How to flash(internal) 1064 using mfg tool
2,899 次查看
vasudhevan
      If we use JTAG how to implement secure boot using internal flash ?
      How to flash dual image 1064 internal flash ?
      How can we use mfg tool flashing internal flash ?
Thanks & Regards
       Vasu
2,755 次查看
kerryzhou
Hi Vasudhevan G,
   You need to enter the serial download mode at first, then use the following UART pins to connect your RT chip and donwload it.pastedImage_1.png
About the download,  I suggest you use our MCUBootUtility tool to download it, it's very easy to use:
https://github.com/JayHeng/NXP-MCUBootUtility/releases/tag/v2.1.0
the related user manual is:
You can try it at first.
If you still have questions about it, please kindly let me know.
Wish it helps you!
Kerry
6 回复数
2,755 次查看
kerryzhou
Hi Vasudhevan G ,
   Answer your questions:
1. If we use JTAG how to implement secure boot using internal flash ?
Answer:
  You can refer to this application note at first:
Secure JTAG for i.MXRT10xx
2.      How to flash dual image 1064 internal flash ?
Answer: I don't fully understand your questions, as I know, RT1064 just have one internal flash. What do you mean the dual image? Just put in the different range? If yes, then I think you can merge two image together in one image file, then download it.
3.      How can we use mfg tool flashing internal flash ?
Answer: You can refer to this application note:
How to Enable Boot from QSPI Flash
Wish it helps you!
Kerry
2,755 次查看
vasudhevan
Hi Kerry,
    We are new to imxrt crossover family.
    2) Dual image means dual binary file flashing at same time one is primary and another one is factory restore.
    3) How to enable boot from QSPI Flash - this document related to external spi flash but i am asking flashing internal flash using mfg tool ?
Thanks & Regards
       Vasu
2,755 次查看
kerryzhou
Hi Vasudhevan G,
  Good question!
  About the boot from QSPI flash, if you check more details about RT1064 internal flash, you will find the RT1064 internal flash is just one winbond W25Q32JV chip put in the RT1064 chip, so the external flexSPI flash operation is totally the same as your internal flash.
Wish it helps you!
Kerry
2,755 次查看
vasudhevan
Hi Kerry,
   Thank you for your reply,
 How to flash imxrt 1064 internal flash using UART1 ?
   Thanks & Regards
           Vasu
2,756 次查看
kerryzhou
Hi Vasudhevan G,
Wish it helps you!
Kerry
2,755 次查看
vasudhevan
Hi Kerry,
  Thank you for your response.
   Further doubt and issue let you know.
Thanks & Regards
       Vasu
