How to enable MIPI CIS Virtual channel on RT117x
1,135件の閲覧回数
ian_ch
If my mipi csi output signal contains virtual channel id,
I refer to the csi_mipi_rgb_cm7 example of sdk and define the mipiChannel of camera_config_t into my program.
This setting does not work, the MCU still receives all virtual channel signals.
How do I set the RT117x system so that the RT117x only receives specific virtual channel signals.
1,117件の閲覧回数
jingpan
Hi @ian_ch ,
We are investigating this issue.
Jing
