How do I handle SDRAM pins when I don't use SDRAM on RT1052?
Should I open the pin? Or pull-up or down? Also, please advise for pin mux of SDRAM ports.
Lastly, what should I do in Software?
Deega
解決済! 解決策の投稿を見る。
Thanks for your reply.
1) Should I choose the GPIOx or the SEMC_xx or not?
-- If you don't use the SEMC pins, it's unnecessary to configure ALT mode for them, in another word, it doesn't need you to do anything.
Hope this is clear.
TIC
Hope this is clear.
TIC
Thank you for your reply. Let me close this.
Deega
1) Should I open the pin? Or pull-up or down?
-- Just keep these pins floating.
TIC
Hi TIC,
I have an additional inquiry, should all SDRAM ports not be defined (NC) in pin mux?
Deega
1) Should all SDRAM ports not be defined (NC) in pin mux?
-- Actually, I'm not very clear with this question, please clarify it again.
TIC
I understand that we can choose the role of each pin in the Pin Mux.
This pins are select to others function below my capture for example.
By the way, if I don't use SDRAM, how should I handle this pin in the Pin Mux?
Deega
