How to create a section in flash as eeprom
3,443 次查看
divithsid
I want to create a section in flash as eeprom. How to do it? is there any demo code available to implement it.
4 回复数
3,412 次查看
Omar_Anguiano
Hello
Hope you are well.
Unfortunately, the RT106x doesn´t have this feature unlike other families with FlexMemory like kinetis K64.
I apologize for the inconvenience this may cause you, if you have more questions do not hesitate to ask me.
Omar
3,406 次查看
divithsid
Im using external flash. can we do it in external flash?
3,375 次查看
jay_heng
You need to create firmware to emulate eeprom, it is MCU chip independent, you can refer to below links for firmware design.
https://electronics.stackexchange.com/questions/258851/flash-eeprom-emulation
https://www.silabs.com/documents/public/application-notes/AN568.pdf
For i.MXRT SDK, we don't have eeprom emulate driver, the most similar design is in \SDK\components\flash\mflash
3,386 次查看
Omar_Anguiano
I suggest you contact the external flash manufacturer. I believe it is not possible to emulate an EEPROM with flash memory.
You can use the flash to store some data however this is not recommended since it will shorten the life of the memory since you will be making a lot of programming cycles.
Omar
