Do I need only some software modifications or do I need also hardware modifications?
Solved! Go to Solution.
Hi @RitaD
You need to do software and hardware modifications since you need an external bluethoot module.
On this link you will find documents to use the SLN-LOCAL2-IOT.
Best Regards, Miguel.
Hi @RitaD
