How to change an audio format of avb_audio_app?
1,113 次查看
tak01
I'd like to change an audio format of avb_audio_app which is contained in genavb-apps-freertos-4.0.3 for MIMXRT1170-EVK.
The handle_avdecc_event() of avb_audio_apps.c receives genavb_media_stack_msg by genavb_control_receive().
And the &msg.media_stack_connect->stream_params has its audio format.
But I cannot find a part of setting the audio format to it.
i.e. Who send the control event for the genavb_control_receive()?
2 回复数
1,073 次查看
tak01
Hi @jingpan ,
Thnak you for the reply.
I'll refer the specification document.
1,085 次查看
jingpan
Hi @tak01 ,
AVDECC is a protocol used to dicover, enumerate, connect and control audio/vedio devices. You can refer to 7.3.2.1.3.2 of AVDECC spec which is about the audio format.
Jing
