How to burn flashloader.srec in I.MXRT1064
anupbhutada4
I am trying to burn flashloader.srec in I.MXRT1064 given on "MIMXRT1064-EVK_EvaluationBoard\Tools\FLASHLOADER-RT1064-1.0\Flashloader_RT1064_1.0_GA\Flashloader" path.
I used GUI Flash Tool and in that I select P&E Micro probes. After that when I ping any command using blhost.exe I am not receiving any response from the controller.So please help me if I am doing anything wrong. Thanks in Advance !
jorge_a_vazquez
Hi Anup Bhutada
Using PEMicro interface, GUI Flash doesn't support .srec files, you have to use a .axf files, sorry for the inconveniences that this may cause you.
TIC
