Hello Netanel,
Having the binaries, you do not need to build the projects again. Using the Flash GUI tool as described in the developer's guide, you can select a file to program from your desktop.
For the different sections, certificates and toolboxes the addresses are provided in the guide.
I'd recommend that you follow the guide step by step even if downloading the projects from the SDK, so you can make sure that you are using the Flash GUI tool correctly as well as the addresses that correspond to each part of the application. Then if you want to try just using the binaries provided, then you may by only selecting the file from your desktop.
Our online support is based on this medium and unfortunately, I cannot provide remote support.
Sabina
