Hardware connection method based on MIMXRT1064-EVK and AW-CM358MA modules
810 次查看
testmb1
Hello, NXP technical support:
I have MIMXRT1064-EVK and AW-CM358MA modules, but I found that they cannot be used directly. Can you provide a reference plan and test code based on the hardware connection method of MIMXRT1064-EVK and AW-CM358MA modules?
Note: There is also an M.2 E key to DIP adapter board (as shown in the picture)
789 次查看
DanielRuvalcaba
In order to use M.2 modules in the RT1064-EVK, you will need a M.2 to uSD adaptor like this one.
The SDK examples already supports this adaptor.
Daniel.
777 次查看
testmb1
Can you provide a simple schematic so that I can make one myself?
745 次查看
DanielRuvalcaba
Sorry but we don't provide that. I'd recommend you use the Murata one.
Daniel.
