Glow Installer for Windows
tkgrahul
Glow installer for windows mentioned here https://www.nxp.com/design/software/development-software/eiq-ml-development-environment/eiq-for-glow... is from July, It does not include model-profiler utility provided by glow.
Could you please provide me new/updated glow installer for windows?
Rahul
jeremyzhou
Ok, I'll check later, however, according to https://www.nxp.com/docs/en/user-guide/EIQGLOWAOTUG.pdf, it seems that the model-profiler.exe is not necessary to profiling the model.
TIC
tkgrahul
Thanks for your reply.  https://www.nxp.com/docs/en/user-guide/EIQGLOWAOTUG.pdf document mentioned about image-classifier tool which is sufficient if one is dealing with image classification model.
However for other type of model (LSTM/NN) model-profiler tool is required. Profiling help in model accuracy.
jeremyzhou
Yes, I agree with your idea, the eIQ Glow compiler seems to be limited to focus on the model to classify the picture currently.
As I know, it will support other types of model in the future, in addition, it also releases a GUI version tool of eIQ.
TIC
