Aniket,
This should put you on the right track: https://mcuxpresso.nxp.com/en/select?device=EVKB-IMXRT1050
For the FreeRTOS, select this option as highlighted below and confirm that the toolchain/IDE is "IAR Embedded Workbench for ARM" before downloading.
Your information is very interesting. Thank you for sharing MyGroundBiz
Hi Aniket
Below is a screenshot of the IAR file folder with the project file highlighted using the "freertos_hello" example.
Let me know if you have any other issues or questions!
Aniket,
