Does the LCD panel of MIMXRT1060-EVK support multi-touch function?
If so, are there suitable examples?
Solved! Go to Solution.
The touch screen controller in the panel supports 5 pens in parallel but doesn't natively support gests (these can however be interpreted from the pens movements in firmware)
The uTasker project's uGLCDLib includes interrupt-driven support for all 5 pens (rather than polling) operation and allows rich-graphics operation without requiring SDRAM.
Attached are two videos showing multiple pens being used - the first in the real HW and the second in the uTasker i.MX RT simulator which also performs real-time touch screen and TFT emulation (emulating all i.MX RT peripherals, interrupts, DMA etc. in approx. real-time) also at https://youtu.be/83-Sc4TqpSc .
I have also attached the (raw) touch screen code to control this (via I2C) to give an idea.
Mark
[uTasker project developer for Kinetis and i.MX RT]
Contact me by personal message or on the uTasker web site to discuss professional training, solutions to problems or rapid product development requirements
For professionals searching for faster, problem-free Kinetis and i.MX RT 10xx developments the uTasker project holds the key: https://www.utasker.com/iMX/RT1060.html
Mark
