Hi Alfonso Sanchez Arellano
Could you please also share some test results on your side, you mentioned: I am trying to parse just 1 number for example when the user says I have 10 apples.
Please give me our test result about it.
About the examples of the CJSON with the Alexa, you can refer to the SLN-ALEXA-IOT SDK code, which can be downloaded from this link:
You can check the code under : SDK_2.7.1_SLN-ALEXA-IOT\boards\sln_alexa_iot\sln_voice_examples
The related code contains the CJSON process code.
For more details, please check the project related readme.txt.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
