Documentation how to use: FreeMarker Linker Script in mcuxpreso
1,366 次查看
e_v_spronsen
I needed to make modification to the linker script. I understand that mcuxpresso uses freemarker. Is there any documentation how to use freemaker linker script in MCUxpresso? Thanks!
1,357 次查看
jingpan
Hi e_v_spronsen,
Please refer to section 17.14 in MCUXpresso_IDE_User_Guide.pdf.
Jing
4 回复数
1,320 次查看
e_v_spronsen
Ok thanks for the help.
1,341 次查看
e_v_spronsen
The documentation is very limited.
Can you help  me how to add this to the linkerscript?
I want to place a const struct at a fixed location in flash. How do I configure this in the linker script?
something like this:
. = 0x2500 ;
KEEP(*(.config_boot))
} >PROGRAM_FLASH
Thanks.
1,323 次查看
jingpan
You needn't modify Freemarker script. Please refer to 17.13.4 in MCUxpresso user guide. It is enough to put a structure in a fixed location.
Jing
1,358 次查看
jingpan
Hi e_v_spronsen,
Jing
