Difference of lite and non-lite source code
1,742 次查看
sathishkumar_r
May I know the pros and cons of using the lite source code(evkmimxrt1060_dev_video_virtual_camera_lite_bm) & non-lite source code(evkmimxrt1060_dev_video_virtual_camera_bm) which is provided in SDK example for RT1060?
Thanks in advance...
1,683 次查看
victorjimenez
Hello Sathish,
When you download the SDK from the SDK builder you will see an option named "Download SDK Documentation". If you download this file, in the path docs/USB you will find a pdf file named "MCUXpresso SDK USB Stack Device Reference Manual". Section 1.1 of this document explains the differences between lite and non-lite.
Victor
- If this post answers your question, please click the "Mark Correct"button. Thank you!
