Datasheets of MiMXRT1175AVP8A(144 pin), MiMXRT1175AVJ8A(196 pin)
534 次查看
venkat7
    I need details of what peripherals available in small form package of  of imxrt1170, they are
MiMXRT1175AVP8A(144 pin) - 10 x 10 mm
MiMXRT1175AVJ8A(196 pin)  - 12 x 12 mm.
I need what are the peripherals available in the above two packages. I googled them but they are not available.
Please send datasheets/manuals of above both part numbers.
Thank you,
K.Venkatarao.
516 次查看
jeremyzhou
Thanks for your reply.
1) Are they not in production yet?
-- Yes, you can think so.
TIC
527 次查看
jeremyzhou
The above two packages are not available, so I'm not assured of they will not contain the peripherals versus MIMXRT1175AVM8A.
TIC
524 次查看
venkat7
Thank you for your reply.
But as per "i.MX RT1170 Crossover  Processors Data Sheet for Automotive Products".
144, 196 pin configuration available. see below pic, are they not in production yet?
517 次查看
jeremyzhou
TIC
