Can VBB_USB_CAP pin be floating?
1,113 次查看
giuseppescarpi
Hi fellow engineers,
the board I'm working has very limited room available. I plan NOT to use USB, so the question is: can I leave VDD_USB_CAP floating?
Giuseppe
1,106 次查看
Alexis_A
Hello @giuseppescarpi,
You can keep USB pins floating. If  USB VBUS is not applied, there is no need to connect the VDD_USB_CAP.
Alexis Andalon
1,107 次查看
Alexis_A
Alexis Andalon
