CST tool generate bin.csf file size
4,306件の閲覧回数
Casper
I'm using the CST tool to encrypt the image and trying to use the HAB API to decrypt that
However, I found the CST tool needs to reference the CSF file.
The CSF file describes the SRK information and certificate.
but when I run the CST tool to generate csf.bin. The size is around 7K always.
Is there any idea to reduce the bin.csf file size?
Thank you.
4,207件の閲覧回数
kerryzhou
Hi @Casper ,
  Yes, of course.
   Please refer to my doc:
https://community.nxp.com/t5/i-MX-RT-Knowledge-Base/RT1050-HAB-Encrypted-Image-Generation-and-Analys...
  It include how to generate it.
Kerry
8 返答(返信)
4,222件の閲覧回数
Casper
Hi @kerryzhou ,
Thanks for the reply.
It's good news for me that the csf file could be reduced to 4K.
I'm using i.MX RT1050
Thank you.
4,213件の閲覧回数
kerryzhou
Hi @Casper ,
   You are welcome!
   I also attach my generated file.
    If you still have question about it, just kindly let me know.
    If your question is solved, please help to mark the correct answer, just to close this case.
   Any new issues, welcome to create the new case.
Kerry
4,208件の閲覧回数
Casper
Hi @kerryzhou ,
Thanks for the csf.bin provided.
May I know how you generate the csf.bin?
Thank you.
As far as I know, the csf data should include the SRK and other information below
4,208件の閲覧回数
kerryzhou
Hi @Casper ,
  Yes, of course.
Kerry
4,035件の閲覧回数
Casper
I found the root cause was the SRK file.
The SRK bin size will affect the generated csf.bin size.
4,172件の閲覧回数
Casper
Hi @kerryzhou,
Thanks for the details information provided.
I will follow the document. once the CSF.bin is successfully generated and the size around 4K will be closed.
Thank you.
4,139件の閲覧回数
kerryzhou
Hi @Casper ,
  You are welcome!
  If you meet any issues, also kindly let me know.
Kerry
4,246件の閲覧回数
kerryzhou
Hi @Casper ,
  Please tell me which RT chip you are using now?
  I have tested the RT1050 HAB function previously, the generated csf.bin is just 4KB.
  So, please let me know your used RT chip at first, thanks.
Kerry
