Break at address "0x200454" with no debug information available, or outside of program code
951 次查看
ikuzmych
I get this error each time I try to trigger an RTWDOG reset on my NXP RT1020 dev board. What is the cause of this and how can I prevent it?
926 次查看
EdwinHz
Hi @ikuzmych,
RTWDOG resets will cause your debugger to loose communication with the MCU, which is why you are no longer able to see any debug information. You would have to disconnect and reconnect the debugger to regain access.
