there is some confusion about the BT_FUSE_SEL fuse in the RT1064 Reference Manual (Rev 2. 07/2021). On page 198 you find:
while on page 1331 you find in table 22-6:
In both tables the resulting options for boot_mode 00b and 10b are swapped. Which one is correct?
Thank you for your help.
Solved! Go to Solution.
Hi @glaukos ,
Thank you for your updated information, the first one is correct:
You just need to know, if the BT_FUSE_SEL is not burn, then BOOT_MODE[1:0]: 00, 01, is the serial download mode, 10 is the internal boot mode from GPIO.
Wish it helps you!
kerry
Hi @glaukos ,
Wish it helps you!
kerry
