I am still new to i.MX RT117x environment but I am requested to find a Wifi/BT module that can work with i.MX RT117x crossover MCU for an automotive application.
So please teach me what automotive Wifi/BT module are avaliable? this means that the drivers for using with RT117x MCU should be ready as well.
Yanfeng
Solved! Go to Solution.
Hi @yfliu ,
SDK support situation:
no 8887 now.
More details, please check the SDK wireless document:
SDK_2_11_1_MIMXRT1170-EVK\docs\wireless
It has the detail information.
Kerry
Hi @yfliu ,
Please check NXP WIFI/BT chip:
https://www.nxp.com/products/wireless/wi-fi-plus-bluetooth:WIFI-BLUETOOTH
Wish it helps you!
Kerry
@kerryzhou, thank you!
Would you mind to confirm if 88W8887 is also supported by MCUExpress SDK? if not, how compatible is 88W8987 with 88W8887?
My expectation is to have a list of SDIO+UART based automotive Wifi/BT modules for futher selection.
Yanfeng
Hi @yfliu ,
no 8887 now.
Kerry
Double checked this page as you mentioned, I saw 88W8897 listed in in automotive section, however, the table doesn't have RTOS listed in "OS/Driver support" column for 88W8987. Does this mean that table is still not up-to-date yet?
Yanfeng
Hi @yfliu ,
It means the 88w8897 self wifi module can support RTOS, but no RT or i.mx driver for it now. Just no related RT driver.
kerry
Thanks for the screen shot.
what I meant to ask is the SDIO based model 88W8987, from your screen shot, its situation is that RTOS and Linux drivers are both available.
Hi @yfliu ,
8987 RTOS code, you can refer to the RT SDK wifi/BT code.
8987 linux code, you can refer to the I.MX SDK wifi/BT code.
Wish it helps you!
kerry
