It says in the user manual that there are 16Kbits of OTP fuses. We would like to use a portion of those to write a serial number. From the fuse map provided in the user, it looks like there could be words that are possibly avail from 0-7, 10-94, 160-335, and 496-512, but not sure if they are reserved for the future or not. Can we use those?
Solved! Go to Solution.
1) Can we use those?
-- No, I'm afraid not, as they're reserved areas that are reserved for NXP internal (and future) use only, or are security-related. Customers must not attempt to burn these.
TIC
TIC
Thanks. I thought so, but just wanted to make sure.
