Hi Leo.
Thank you for your reply.
-If Tj is below 105 degrees and 800MHz, it can use internal DCDC converter.
-If Tj is below 125 degrees and 800MHz, it need to use PF5020.
-And this condition is not affected by the presence or absence of CM4.
This is my understanding, but is this correct?
Best regards.
