An equivalent circuit of GPIO_EMC about RT1021
1,644 次查看
Edgard
Dear an Engineer in NXP,
I would like to know the equivalent circuit of GPIO_EMC pin.
Because I want to check the input mechanism.
Recently, GPIO_EMC_41 was broken, I think the electrical over stress (EOS) occurred to the pin.
I will put the 100 ohm resister close to pin in order to protect the pin from EOS.
But I wonder if the value of resister is large or not...
Thanks in advance.
Kindest Regards
Edgard
1,552 次查看
EdwinHz
Hi @Edgard,
Application Note AN5078 describes everything relating the pins on our MCUs. With respect to ESD and EMC protection, please look into AN10853.
BR,
Edwin.
1,539 次查看
Edgard
Hi @EdwinHz
thanks, I checked the App.Note you mentioned.
Kindest Regards
 Edgard
1,553 次查看
EdwinHz
Hi @Edgard,
BR,
Edwin.
