Hi All,
I would like to know the max baud rate supported in imxrt106s for LPUART6. I want to interface uart6 of imxrt106s with a processor. I set baud rate as 500000 at both controller and processor side.But communication is not happening.Communication is happening only in baud rate 115200 .I changed the config->baudRate_Bps baud rate from 115200 to 500000 in the LPUART_GetDefaultConfig()[path of the file is :drivers/fsl_lpuart.c] in the sln-local2-iot local demo sdk.Do we need to change any other parameters to make it work in 500000 baud rate.Kindly help me
@kerryzhou Could you please help me on this?
