Hello community,
At my project we need to use M2 Wifi/BT device and uSD card. As I understand, these two ports use one hardware SD1 port. And result, I can't be use these two devices at the same time? Correct me please? Maybe we have some software solution?
Thank you in advance for contacting NXP support.
You can use both the SD and the M2 on a custom board of the RT1170, but if you are working on the EVK the hardware design does not allow this. Please let me know if I can help you on anything else.
