10 bit RGB Image on IMX RT
sundaram_v
Hello Team,
Is it possible to generate 10 bit RGB image from iMX.RT series? If yes, please help to share the procedure.
Please help to suggest.
Sundar
kerryzhou
Hi @sundaram_v ,
  Please tell me which detail RGB mode you want, normally, RGB is RGB 565, RGB 888, RGB555.
   Do you use the LCD or the CSI?
  Please tell me your 10bit RGB detail format, then I can help you to check the details, just from the RGB method of RGB565, 555,888, I didn't find the 10 bit RGB.
  So, need your more information, then I can double check it on my side.
Kerry
