yocto udhcpc problem
3,262 次查看
meeeeeei
Hi:
I use udhcpc -i eth0 command in IMX8MP yocto system to get ip address, but eth1 node will be down, why
10 回复数
3,244 次查看
Zhiming_Liu
Can you see eth0 with ifconfig?
3,237 次查看
meeeeeei
Hi: Zhiming_Liu
ifconfig has only eth0 nodes,All other wlan0 eth1 nodes are down
3,225 次查看
Zhiming_Liu
Please check the driver status
3,217 次查看
meeeeeei
How to check the driver state, I found that only the first time to use udhcpc will appear this problem, and the automatically obtained ip address will not take effect, after the use of udhcpc will not have this problem, I wonder if you have found this problem before
3,201 次查看
Zhiming_Liu
Can you share BSP version? Let me check it on my side.
3,197 次查看
meeeeeei
My bsp version is 6.1-langdale.
3,061 次查看
Zhiming_Liu
This is udhcpc command issue, the udhcpc will down the another interface on userspace layer.
3,045 次查看
meeeeeei
I found that Ubuntu system udhcpc has no related issues, then how to solve this problem
3,005 次查看
Zhiming_Liu
When we run the udhcpc command it will disable all the interface,but only enable the one we used currently at last. For the detail information you can reference the /etc/udhcpc.d/50default script. You can enable the other interface using ifconfig tool.
ifconfig eth0/eth1 up
3,111 次查看
Zhiming_Liu
We are trying to find root cause
