wang@wang-VirtualBox:~/fsl-release-bsp$ DISTRO=fsl-imx-x11 MACHINE=imx6qsabresd source fsl-setup-release.sh -b build-x11
Build directory is build-x11
Configuring for imx6qsabresd
File "<string>", line 1
import sys; print sys.version_info >= (2,7,3)
SyntaxError: invalid syntax
BitBake requires Python 2.7.3 or later
ERROR - No build directory is set yet. Run the 'setup-environment' script before running this script to create .
wang@wang-VirtualBox:~/fsl-release-bsp/sources/poky$ python --version
Python 3.4.3
my python version is 3.4.3 is later than 2.7.3 .so What's the reason?
