yocto 6.1.36_2.0 imx8mm 환경에서 local.conf 파일에
tslib을 설치하려고 합니다.
IMAGE_INSTALL_append = "ts_calibrate ts_conf ts_test ts_print" 를 추가했는데, 아무 소용이 없습니다.
that depend of your LCD since we have no an LCD that need calibration for MX8MM.
regards
I'm testing with freescale 8MMINI-BB ref board
Where should I set up the LCD?
No for the BB board you will need to use a MIPI-DSI to HDMI. since it does not came with LCD interface.
