wpa_supplicant: inaccessible or not found in android 12
3,483件の閲覧回数
diwakar2599
For Bring up the wlan0 interface and then start the wpa_supplicant daemon in the background
127|mek_8q:/system/bin # ip link set wlan0 up
127|mek_8q:/system/bin #wpa_supplicant -B -i wlan0 -c /data/misc/wifi/wpa_supplicant/wpa_supplicant.conf
/system/bin/sh: wpa_supplicant: inaccessible or not found
This the error I am facing pls help me out to solve this issue
3 返答(返信)
3,446件の閲覧回数
AldoG
I believe you're using the incorrect path for wpa_supplicant.conf
/vendor/bin/hw/wpa_supplicant
Please try with the one above and let us know of the results.
Aldo.
3,432件の閲覧回数
diwakar2599
Hi @AldoG
I have tried with this
mek_8q:/vendor/bin/hw #wpa_supplicant -B -i wlan0 -c /data/misc/wifi/wpa_supplicant/wpa_supplicant.conf
3,427件の閲覧回数
AldoG
I meant that, the path you're selecting for the configuration file is not correct, your command should look something like this:
wpa_supplicant -B -i wlan0 -c /vendor/bin/hw/wpa_supplicant/wpa_supplicant.conf
Aldo.
