I'm able to detect wm8960 codec in android 11 on imx8mp phytec pollux board
Issue is: i'm able to play audio through command line means through tinyalsa commands audio is playing through wm8960!
but unable to play audio through GUI, so please help me out like which modification i have to do and in which file?
Does in AudioPolicyConfiguration.xml here i have to do modification?
Or in any other files?
IMX8MPLUS
Hello @Satyaprakash ,
I hope you are doing well.
->Please make sure to update the sample rate in the android_configuration.xml file.
->For more details please follow the below link -> Section Using MediaPlayer in a service.
https://developer.android.com/
I hope this information helps you!
Thanks & Regards,
Sanket Parekh
