1. the ddr show wrong size, our platform use 3GB ddr only , but it show up 6GB, how to modify it ?
A: Are you using NXP board or customer design board? If customer design is 3GB, have them modify in the source code? Which version BSP are they using?
2. there are too many disk warning(show as below ) , what cause the warning ? Does there anyway to fix it ?
A: Warning will not effect using, you can ignore them.
