wifi base wakeup from Deep sleep mode imx8m mini evk board
anilpathrut
Hello Sir,
I need to implement wifi base wake up  from Deep sleep mode on imx8m mini evk board.
how to proceed for this, which document need to refer for this
Please suggest for this.
Hi Anil
in general solution could be that WiFi module will issue a interrupt to the i.MX8MM to wake up
the system from SDIO, however it is not implemented in BSP.  May be recommended to
use external GPIO from WiFI chip  to wakeup system from suspend.
